I CV.....questi sconosciuti (e spesso abusati in quantit?)
#21
Citazione: i due tracciati si incrociano a 5252 giri SEMPRE
:hum:
:hum:
Understanding the relationship between Horsepower and Torque and how to mathmatically calculate it.
Contributed By: Enginebasics.com
  Understand the Basics of Power
Since any of us became interested in engines, we have been interested in power. Power is defined as the amount of work we do in a given time. Or by the equation:
P= Work/Time
So really when we describe something as having a lot of power, we are really saying that it can do a lot of work in a small amount of time. This helps us put perspective on what we are really talking about when we are looking at engine power. In the automotive world we look at two American Standard units we call Torque and Horsepower. What most don’t know is that these two units are intertwined and inseparable. Because of this the goal of a well-powered engine is going to be one with both HP and TQ being very similar to each other. Engines that reliably make both will provide power all the way through the RPM rev range and be very fun to drive.
What is Torque?
The equation for Torque is:
Tq=Force X Lever Arm Distance
So it is the amount of force applied over the length of the lever arm measured from the fulcrum to where you applied the force. In the case of an engine, this would be the force the piston and rod applied on the crank, multiplied by the length of the crank arm. One can then understand why when an engine builder strokes a motor by putting in a longer crank, the motor gains a healthy amount of torque.
What is Horsepower?
Horsepower is a measure of the amount of Work the engine does over a given Time. The basic definition of Work is:
Work = Force x Distance
Therefore: Horsepower = (Force x Distance)/Time
But what we are talking about here is the relationship between Horsepower and Torque. Torque is basically the force that we are talking about in the above equation. So if we substitute that, and clean things up a bit, what we are left with is the following equation:
Horsepower = (Torque X RPM)/5252
John Cooley had the following to say on the matter:
“This actually tells us a lot of interesting things. The first is that at 5252 RPM, an engine’s Horsepower should equal its Torque. I think that you will find that if you look at pretty much any dyno plot of any car, the torque curve and horsepower curve will cross right around 5,200 rpm’s.
[Immagine: HP%20vs%20torque.jpg]
The next is that no matter how much torque our engine makes, the amount of horsepower that it produces is directly dependent on how fast the engine is spinning.
Ever wonder how a Honda S2000 can make 230 Horsepower, but less than 200 Ft Lbs. of torque? Well, the early 2.0 Liter S2000’s have a 9,000 rpm redline. If it is spinning that fast, it doesn’t have to produce a lot of torque to make a lot of power. If you plug 230 horsepower and 8,000 rpm’s into the equation above, you should find that you only have to make 150 Ft Lbs. of torque to generate that much power.”
Conclusion
Except in instances of extremes in engine RPM, like with a low revving diesel, or a high revving motorcycle, your goal should be to have as broad of a power band as possible, and therefore a torque and horsepower number as similar to each other as possible. For more information on how to modify your engine to obtain this check the other articles found here on enginebasics.com
Non e che Ragno parla di prove per motori barca??
Mi sembra che i motori barca hanno il cam particolare e  vogliono il max tq. al massimo dei giri..
No??
BLACK CAT il 5252 è il fattore di conversione delle unità di misura...... perchè nei grafici su ,olte brochure non si incrociano a 5252 rpm????
Gli americani "sono fortunati" perchè utilizzano dimensioni che rappresentano numeri simili sia per la coppia che per la potenza, quindi se fai un grafico con all'asse Y valori di Pw in hp e di Tq in lbxft ile due curve si incrociano per forza (*), ma solo perchè hai usato una scala particolare
(*) @5250 rpm     1 lbxft coincide a 1 hp:       1lbxft  x 5250 rpm / 5250 = 1 hp
se usi altre scale si incrocerebbero da altre parti:
va bene. e allora ?
in genere su questo forum si parla di motori americani ...
quando si fa una ricerca per un motore made in USA di solito ti vengono forniti i dati i valori in lbs ft e hp , misure in pollici e galloni e libbre ... mi sembra naturale che se si parla di motori americani si usi il loro sistema...  avendo svariati libri sui motori v8 chevrolet mi sono documentato su questi.
... paese che vai usanza che trovi ...
L'AMERICA E' UN GRANDE PAESE
Ognuno fa il grafico che vuole a seconda che voglia convincerti se i suoi prodotti diano grande spinta qua o la
[Immagine: busa%20dyno%20info002b.jpg]
[Immagine: normal.jpg?pool=multimedia&type=image&id...4a31150f7f]
[Immagine: 2014-Corvette-LT1-V8-TorqueHP.jpg]
[Immagine: power-39.gif]
quello che conta alla fine è questo
[Immagine: thrust_hp_speed11352904904.gif]
@mustanghino  : qual è la tua tesi ? cosa si dimostra nel grafico sopra
poi ti diro che quello che conta , per ME non sono ne grafici , ne fogli di carta , ne brochure .... gli unici HP che contano sono quelli che mi portano da A a B nel minor tempo possibile ad una data velocità.
vuoi sapere quanti HP veri stai sviluppando  ? peso della vettura e velocita di uscita sul quarto di miglio... tutto il resto son chiacchere da bar
JMHO
riguardo le rappresentazioni grafiche, se si vuole esaltare con la vista, un forte tiro, bisogna far si che la curva di coppia appaia piatta, quindi la si schiaccia (classico metodo)
nella realtà se usi sul 1/4 di miglio, devi fare in modo che l'auto vada a manetta a fine percorso: ogni km/h conquistato dopo i 400 m significa potenza buttata (per il 1/4 di miglio)
insomma un'auto con 300 hp DIN dovrebbe scaricare tutta la cavalleria fino al rapporto piu lungo in 400m: ad occhio e croce ti serve un rapporto finale che garantisce i 200 km/h @ rpm di Pmax + 10%
Citazione:riguardo le rappresentazioni grafiche, se si vuole esaltare con la vista, un forte tiro, bisogna far si che la curva di coppia appaia piatta, quindi la si schiaccia (classico metodo)
cosa vuol dire potenza buttata scusa  ? per fare un calcolo devi usare dei parametri .. uno di quelli son 400 metri .
esempio concreto Confusede la macchina pesa 1800 kg e passa a 160 kmh sviluppa in quella determinata corsa 320 hp
cosa significa?
immagina che hai il tuo bel motore ben pompato con tot cavalli
devi fare una gara di accelerazione? 0-100 km/h, 0 -220 km/h, 0-300 km/h, 0 - 400m, 0 - 1000m quello che sia, non importa, il nostro obiettivo è accelerare il più forte possibile. Ora la fisica insegna che se tu stai a Rivanazzo o su un pianeta orbitante intorno a Sirio o fare la fila a Panaroma alla cassa, una cosa è certa: F = m x a ( forza = massa x accelerazione), che tradotta vuol dire
accelerazione = forza / massa
per accelerare tanto o usi tanta forza, o dimagrisci tanto (che non è male, mancano solo 9 mesi alla prova costume)
tu non vuoi dimagrire (peccato quel telaio in fibra di carbonio era tanto bello)? Ok mettici più forza
"La forza chi te la da?"
"Il motore."
"e come te la da?"
"Attraverso un tubo che gira, che poi fa pappa e ciccia con delle rotelline dentate, che poi trasmette tutto tramite un altro tubo alle ruote, che non vogliono avere responsabilità e quindi scaricano tutto alla povera pista."
"quanta forza eroga il mio motore?"
"Dipende"
"Da cosa? io leggo cilindrata, potenza coppia etcc, mai forza"
"La forza è intimamente legata alla potenza, ma al contrario di questa risente di tutto ciò che sta a valle (trasmissioni): sappiamo cosa lega potenza e coppia (che è parente stretta della forza), Pw = T x rpm x K1, la potenza è pari alla coppia per i giri al minuto che sono una misura di velocità angolare: K1 è una costante che funziona ne piu ne meno di convertitore di valuta a seconda dei valori con cui noi mortali misuriamo le grandezze in gioco (KW, HP, daNm,lbsxft ecc): a noi adesso non importano i numeri, conta il concetto quindi ce ne sbattiamo di questo K1"
"vabbehhh di questo abbiamo già parlato in queste pagine"
"Calma lo ripeto solo per farti vedere come coppia e forza sono legate intimamente"
"Come esiste una relazione tra coppia e potenza esiste una formula che lega potenza e velocità in meccanica"
[Immagine: 2014dafdb211678f75c87b483ab58c12.png]
"tranquillo scherzo, è più semplice"
Pw = F x v x K2
"Potenza è uguale a forza per velocità. A parte quel K2 che è il solito convertitore di valuta che a noi non frega un piffero (per ora), non trovi qualcosa di simile a quanto detto prima?"
Pw = F x v  ; Pw = T x Rpm
"in matematica esiste un detto: se Tizio è uguale a Sempronio e Sempronio è uguale a Caio, allora Tizio è uguale a Caio, quindi QUALITATIVAMENTE (lasciamo le varie costanti K1, K2 a dopo) abbiamo"
F x v = T x Rpm ;      F = T x Rpm /v
"La COPPIA fa la FORZA, tanta coppia tanta forza, a parte quella seconda parte di formula Rpm/v che per ora chiamiamo K3"
ora torno a lavorare...... mi sta finendo l'ispirazione.... a dopo
mi è piaciuta la tua spiegazione e in Usa già ai tempi sintetizzavano con : "hp sells cars ...torque wins races "
comunque si parlava di hp sulla carta e hp sviluppati su strada o pista per far un determinato lavoro...
e per finire un auto con 300 hp DEVE pesare 850kg con pilota per fare i 400m a 200kmh
dicevo cosi ad occhio............ comunque
1) visto che la tua chevelle non peserà MAI 850 kg vuol dire che a 400m ci arrivi sotto i 200 km/h in ogni caso, quindi i rapporti devono essere molto corti, ma ci arriviamo con calma
2) per il detto diciamo che è veritiero per 3/4, ti anticipo che il concetto base è
La potenza ti indica COSA può fare la tua belva, la coppia è COME lo fa, e (bocca mia taci), qui lo dico e qui lo nego, che in parole semplici e crude che mentre la Potenza ti indica la QUANTITA', la curva di coppia (piu che la coppia in se, perchè puoi avere la coppia di un locomotore per 100 rpm e poi il deserto intorno) la QUALITA'
si dice anche che la potenza è a quanto riesci ad andare contro un muro e la coppia è di quanto lo sposti :zsarcastic4xx:
Quante storie....io conosco uno che ha 650 hp al banco e 700 alla ruota.............................................. :ciappa: :ciappa: :ciappa: :ciappa:
se poi ha un cambio shimano da mountain bike i 650 hp rimangono li al banco (dei pegni)
Velocità di uscita -Trap speed mph NON è molto influenzata come pensi dal rapporto al ponte , gomme o quant altro .. ed è proprio per questo motivo che è un buon indicatore dei hp sviluppati dall auto
ti dico questo per esperienza personale fatta proprio a rivanazzano in pista , mentre l ET tempo di percorrenza dipenda da trazione  rapporti , rapporti cambio  , rotolamento pressione pneumatici etc etc etc
mattina
gomme stradali  ET 15.4 a 176 kmh
pomeriggio
slick ET 13.3 a 179 kmh
cambio rapporto al ponte da 3.31 a 3.73 ruote identiche da 26 pollici
12.66 a 181kmh con i 3.31 miglior tempo
12.44 a 179 con i 3.73 miglior tempo
vedi che "ballano" 4 kmh di velocità di uscita un nonnulla adiittura con le gomme stradali ... cambiando il rapporto posteriore con le slick pressoche identiche le velocità  ma ben 3 second di ET !!!!!!.... (150 metri di distacco tra la prima corsa e l ultima )
Ah la chevelle pesa 1920 kg -4250 lbs con un quarto di sebatoio e pilota
qui se volete leggerne in inglese lo spiega bene....
  1. Trap Speed will tell you about your HP to weight.
  2. ET will tell you more about traction and your launch.
After running lots of quarter miles, it becomes clear that how well you do in the first 100 feet of the track is KEY to a good time. The last half of the track is KEY to a good speed.
Let's use an example of a stick-shift mini-pickup that on a perfect run, gets a timeslip of 19.50 seconds at 70.00 mph in the quarter.
Imagine that the light turns green, the truck moves two feet and the engine dies for three seconds. After restarting the engine, the driver proceeds to then complete a perfect pass. His time slip would show 22.50 seconds at 69.97 mph. The ET was 3.00 seconds high but the speed was almost unaffected.. why?? It's because his racetrack was 1318 feet long instead of 1320, and in those last two feet this truck usually gains an additional 0.03 mph. However, the clocks recorded the long time. My point? Much of a great ET is made by a great launch.
Now take this truck again, and the driver leaves right on the green light. However, he misses the 3-4 shift when he's at 1250 feet. He coasts for the last 70 feet while trying to find fourth gear. Now instead of accelerating another few mph in this final 70 feet of the track, he decelerates over this distance. His timeslip; 19.51 at 67.83 mph. Note how the et is almost perfect (only off by 0.01 second) but the trap speed is way off (over 2 mph slow)! On a good run, traveling that last 70 feet at an average of 69 mph, would have taken .692 seconds. At a 68 mph avg., that 70 feet takes .682 seconds. That's why his ET only varied by .01 seconds, yet the trap speed was 'way off'. My point here: the end of the track is critical to trap speed; shift rpm, missing a gear... these are the big players.
Hopefully these examples are clear. Neither of these runs are 'perfect' runs, it's just that one has an error at the start, one at the finish and the results are obvious. The start of the track is a big player in the ET, but a small player in the mph. The end of the track is a big player in the mph, but a small player the ET.
So for the casual T-Bricks member who wants to get a HP value, you don't have to buy slicks, or wish you had a limited slip differential. You don't really need to heat the tires in the waterbox, or launch with huge power braking. As long as people get their shift rpm right and don't miss a gear, even a rookie will get the appropriate trap speed for their vehicle.. but honing the perfect ET. requires being rude to a clutch, buying steeper gears or slicks.... hey, we're trying to make this recreational.
Ci si può mettere meno di un altro ma uscire dai 400 a velocità minore....
se ci metti meno tempo, ma esci a velocità minore significa che hai ottimizzato meglio tutto quello che hai............se hai una velocità d'uscita relativamente elevata, significa che hai potenziale da sfruttare, ma ci devi lavorare
[quote name="BLACK CAT" post="508232" timestamp="1382437633"][quote name="Serpiko" post="508224" timestamp="1382432787"][quote name="BLACK CAT" post="508206" timestamp="1382423811"]
TQ  X RPM HP  = ---------------                   5252 cavalli = Coppia moltiplicato i giri  diviso : 5252 (che è una costante)[/quote]TQ in Nm, Kg o in lb-ft ?[/quote]
Hai ragione dovevo specificare : Tq espresso in lbs ft
Comunque c e palesemente qualcosa che NON torna nei numeri dati da Ragno
Allora 429 ( 7 litri ) intanto ok la curva piatta ma e comunque sempre in discesa poi comunque al massimo di coppia non corrisponde mai il numero max di cavalli , basta vedere un grafico per rendersene conto , i due tracciati si incrociano a 5252 giri SEMPRE
Inoltre amettendo che i dati son giusti , facendo il conto verrebbe 690 lbs x 6500 diviso 5252 = 853 HP = 120 hp litro
E come si e detto precedentemente
Va bene che erano under rated negli anni 70 .... Ma mi sembra troppo , sicuramente c e un errore di dati ... (Azz sti Fordisti sempre a pompare i numeri ...Smile )
Questi valori sono da big block spinti con teste c alluminio , roller cam etc etc e minimo da 500cid in su
Sicuramente qualcuno ha le specifiche del 429[/quote]
Parlavo dei motore che avevo,non certo stock,erano i 429nascar,la coppia massima di(rettifico) 90,3kgm era a 6500 giri,e davano ben 587 hp,i giri sfioravano gli 8000,ma ovviamente la coppia scendeva!!
